Feature – Kevins FC3S Revisited
Historically, the colour red has always been a conduit for emotion. It can convey both love and anger, it is strong but not overpowering, bold but not over the top. Brands like Ferrari have used the color red, or Rosso Corsa as it’s called, to enhance their brand and evoke emotion from the onlookers. Mazda introduced their shade in the middle 80’s called Classic Red and it is still one of the first things that crosses your mind when you think about Mazda in that era. That and their awesome RWD sportcars that were often powered by magic triangles.
IMG_8528
Which brings me to our subject of today. Whether it be parked in a commercial PA in Oosterhout or carving through the Carrousel at the Nürburgring, there is virtually no way of missing Kevin’s RX-7 FC3S. It is agressive, out-there and loud. And I mean both aurally and visually loud!
IMG_8359
Kevin has been working at improving his car for some time now. Last year Rens posted a short blog about the FC3S, but that was before the major exterior overhaul was started. Kevin has been teasing the interwebs with vague shots, and so everyone was excited to see it in the flesh when we went on our Ringweekend.
IMG_8390
The first thing you’ll notice when you look at the car is the wing. I mean; THAT WING THOUGH! It’s not quite as wild as the thing that come out of Big Country Labs in the US, but there is no denying that it firmly states the intent of this car: Function. Most spoilers on streetcars are more of an aesthetic choice than anything else but this time, the height and tilt of the deck follows the flow of the air that moves over the roof creating quite a bit of downforce.
IMG_8394
In fact the whole car was revamped exterior-wise. Next to the wing the car now sports a Foresight front bumper and sideskirts. Kevin also made a custom front splitter to help attack the corners at the Grüne Hölle. The new bumper also makes a bit more room for the V-mount rad/intercooler setup that will be going in the car this winter. I know from personal experience that a V-mount setup works really well in keeping the hot-headed rotary engine cool.
IMG_8387
Moving to the rear of the car we can see another bit that aids the stability of the car. The Shine Auto diffuser and Vortex-generators help keeping the rear planted through corners and aid high-speed stability. In my personal opinion you simply can’t go wrong with a RE-Amemiya-ish diffuser on the FC3S. Kevin also replaced the rear bumper with an USDM example whilst the rear lights were changed for Japanese units.
IMG_8506
To make sure all of that downforce is translated to the wheels the car is equipped with some custom-spec Intrax 1k2 coilovers. Prothane bushings are used in the Super Now and Mazdatrix lateral and camber links which, in collaboration with the Intrax adjustable tophats, make the McPherson suspension fully adjustable. Racing Beat, a very renown company in Mazda realms, provides stiffness and adjustability in the sway bar departement.
IMG_8419
The car rolls on a set of 17″ 5zigen GN wheels measuring 6,5 and 7,5 inches in width front to rear respectively. Falken Tires provides the grip with a set of sticky Azenis.
Stopping power is provided by the stock-but-capable Mazda calipers clamping down on Stoptech slotted rotors via Hawk HP pads. The ABS system was removed and Earls Performance braided lines were used resulting in a firm and direct pedal feel.
IMG_8437
As you’ve seen so far, Kevin put a lot of thought in creating mechanical grip. A pair of Bride buriddo Low Max seats and Willans harnesses…
IMG_8518
… coupled to a Cusco bolt-in cage make sure he is kept at the helm even in higher G situations.
IMG_8460
Engine parameters are displayed on a trio of Defi Advance BF gauges showing oil temperature, coolant temperature and boost pressure.
IMG_8471
A Defi Advance control unit logs the gauge values and can play back the peak readings. Also seen here is the AVC-R, a neat multi-function boost controller by Apexi. I know from personal experience that Apexi electronics work very well on turbocharged 13Bs…
IMG_8462
… so I was very pleased to see that the car is running an Apexi PowerFC engine management system with the optional Commander unit that lets you display and modify a variety of settings. The PowerFC was never made for the FC(which is quite ironic given its name) so a Banzai Racing loom adapter was needed to make the engine run. Speaking of the engine…
IMG_8504
The engine is the 13B that came with the car but it has been streetported and rebuilt with MCR bearings and uprated apex seals. Boost is generated by a BNR Stage 4 turbo that, until the V-mount arrives, breathes via an Apexi filter through the stock top-mount intercooler into the the stock plenum that has been converted to single throttle. The EGR and airpump were removed as well as the airconditioning to preserve power and shave some weight off the front. Cooling is handled by an aluminium Koyorad dual-flow radiator.
IMG_8503
With reliability being somewhat of an issue with the Wankel engine it’s wise to invest in those areas that make the engine run better. The HKS Twin Power system amplifies the spark making the engine start better(thus lowering the chance of an engine flood) and keeping a more consistent spark as the boost rises. Magnecor leads are also implemented to maintain a strong spark.
IMG_8486
Next to a spark a screaming rotary engine needs fuel, lots of fuel. After reading this article, it shouldn’t be much of a surprise if I said that this departement has been well thought out too.
IMG_8478
Let’s start in the back. A Walbro pump picks up the fuel from the tank which is then transferred to a 2l big swirlpot which is made by Alloy Racing Fabrications. This fuel is then sent to…
IMG_8482
… the first of the 2-stage fuel filters. It then flows into a Bosch 044 main pump. Fuel is then filtered again before it’s sent to the front of the car. All lines are braided stainless steel with Earls fittings and couplings.
IMG_8493
Up front, pressure is regulated by an Aeromotive unit. The Aeromotive FPS is famous amongst rotorheads because of it’s precision, reliability and pressure range.
Fuel is then sent on to a pair of KG-Works fuel rails that feed the Injector Dynamics 725cc primary and 1000cc secondary injectors.
IMG_8063
As it sits the car produces around 315hp and 340Nm at low boost as it awaits final mapping which will happen after the V-mount and a new inlet manifold is installed. I haven’t had the chance yet to sit shotgun in this car at the track but I know for sure it is already a very potent package and I cannot wait until it’s been mapped.
IMG_7943
Kevin has mentioned to me that he plans on getting into the 9’s on the Nordschleife and there isn’t a doubt in my mind that he will get there. Purely functional yet aesthetically pleasing, Kevin has created something that you don’t see everyday, especially not here in Holland.
IMG_8736
Referring back to the first paragraph, I can see why Mazda chose to produce many of their iconic cars in Classic Red. Even in stock form, these cars aren’t silent, or luxurious, or fuel-efficient, yet they manage to evoke something in the hearts of those who drive them. Whether it be blasting through the Touge, drifting the docks of Yokohama or cruising the Wangan, cars enable us to clear our minds of the struggles of life and for some time it’s just you, your car and the open road ahead. Driving emotion.
Zoom Zoom.
Pictures by Alex Kamsteeg
Words by Bop Westerduin
Share on Facebook81Tweet about this on TwitterShare on Google+0Share on Reddit0Share on StumbleUpon0
