[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4824: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4826: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4827: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4828: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
Wanganwarriors.com • View topic - openluchtfilter.
Page 1 of 1
openluchtfilter.
PostPosted: 31 Oct 2012, 19:54
by Beez
Goede dag,
Ik heb me beetje ingelezen op info.
Maar ik vind over de subaru impreza op sommige forums er problemen ontstaan met de openluchtfilter.
Iemand ervaringen die hij/zij wil delen.
mvg
PostPosted: 31 Oct 2012, 19:56
by bob.
Een open-luchtfilter zorgt voor een betere doorstroom van de lucht naar het motorblok. Een subaru werkt met een LLM en dit is een gevoelig onderdeel. Doordat er een betere flow ontstaat, kan er ook meer vuil de motor in. Ik verwacht dat dit vuil op de LLM kan komen en hier storingen etc uit voort komen.
PostPosted: 31 Oct 2012, 20:51
by Beez
zo iets had ik al begrepen. maar als je er voor zorgt dat er weinig tot geen vuil binnen komt moet het dus geen probleem zijn.
De kans dat er vuil bij komt is natuurlijk altijd groter dat besef ik.
PostPosted: 31 Oct 2012, 21:21
by Opgedronken
Als je daar bang voor bent kun je wat gaten boren in je airbox net voor je luchtfilter.
Dan heb je het geluid van een open filter, maar wel nog de filtering van het standaard filter.
PostPosted: 31 Oct 2012, 22:53
by Kapitein Iglo
Dat verhaal met die filters gaat voornamelijk over geoliede filters. Van die goedkope dingen bevatten vaak een olielaagje. Dat zuig je mee naar binnen en dat gaat op je MAF zitten waardoor die stuk gaat (wat sowieso al een verdomd vaak voorkomend probleem is).
Dus als je een goed Apexi filter ofzo koopt, die niet geolied zijn, dan heb je er minder snel last van.
Maar als ik een advies moet geven: koop die shit niet en stop je geld in wat zinnige mods. Een ander luchtfilter zou ik alleen monteren als je niet anders kan (door plaatsing van een FMIC bijvoorbeeld, dan past het originele filter niet meer).
PostPosted: 01 Nov 2012, 12:49
by Beez
Oke, Bedankt voor de antwoorden. Kwaliteit van filters zegt al een hoop.
Wat zoude dan zinnige mods zijn?
PostPosted: 01 Nov 2012, 12:56
by merijndj
Ipv een open lucht filter, zorg ervoor dat koele lucht makkelijk bij je luchtfilter komen kan.
Re:
PostPosted: 01 Nov 2012, 14:21
by Kapitein Iglo
PostPosted: 01 Nov 2012, 15:24
by Beez
Oke, wegligging & gewicht etc....
PostPosted: 01 Nov 2012, 22:03
by Patrick
Ik heb op mijn volvo een K&N luchtfilter, dit is ook ge-olied. en het blok werkt met een LMM (en turbo). Ik zelf heb er nog geen problemen mee gehad, maar heb ook wel eens vaker van bovenstaande gehoord... Als je het filter te te dik in de olie doet gaat het prima !
Re: openluchtfilter.
PostPosted: 01 Nov 2012, 22:39
by Vincent_R
Ik heb ook een K&N die ge-olied is en daarna komt er bij mij ook een LMM. Heb er nog geen problemen mee gehad, maar wat ik veel op het inet lees is dat je er gewoon voor moet zorgen dat je er niet te veel olie op doen na het reinigen.
Droog of ge-olied heeft beide zo zijn voors en tegens.
PostPosted: 02 Nov 2012, 14:09
by Beez
Ge-olied houd natuurlijk meer tegen. Op sprintscooter had ik dubbellaags Ge-oliede filter. Maar het is dus wel mogelijk. Ik ga er is over nadenken met deze info.
PostPosted: 04 Jan 2013, 00:33
by Damon
Als je dan zoiets wilt als een "upgraded" luchtfilter, is het bij die dingen niet verstandig om een air filter box te nemen?
Zoiets als dit van ARC: Image
PostPosted: 04 Jan 2013, 22:10
by Patrick
eigenlijk zou je een heeeeel groot filteroppervlak moeten hebben zodat de motor altijd voldoende kan aanzuigen en dan houd je de luchtstroomsnelheid (4x woordwaarde) in het filter laag, waardoor het goed gefilterd word :)
PostPosted: 04 Jan 2013, 23:04
by The Doctor
er zijn verschillende LMM's he, je hebt ze o.a. met een klep en Subaru gebruikt het systeem met een draadje.
Die met een klep (en het systeem wat Nissan gebruikt, al heb ik dat nooit begrepen hoe het werkt) hebben niet zo'n last van geoliede filters, die met een draadje wel :)
PostPosted: 05 Jan 2013, 09:47
by Eric
Er zijn ook Nissans met gewoon een draadje erin, die worden net zo snel goor met alle gevolgen vandien.
Luister naar heer Iglo, modificeer eerst andere dingen, die lucht komt evengoed je motor wel in.
PostPosted: 07 Jan 2013, 14:49
by Terror010
Ik heb nog altijd goeie ervaringen met de Pipercross kits. is een afgsloten filter met een luchtslang eraan. Maar ook hierbij geldt, onderhoud is alles..
PostPosted: 08 May 2013, 14:43
by Yven
Ik rij met een Apexi power intake op mijn Subaru, maar dit komt vooral omdat ik een FMIC heb. Geen problemen mee gehad de afgelopen 2 jaar. Maakt een heftig aanzuig geluid. Als je geen FMIC hebt zou ik gewoon met het standaard luchtfilter blijven rijden.
PostPosted: 28 Aug 2013, 22:13
by Jefke
Wat Yven al zegt, als je een FMIC hebt is dat wel nodig aangezien de plaats waar de standaard luchtfilterbak zit nodig is voor de doorvoer van je FMIC. De impreza en dan de EJ20 en de EJ25 hebben inderdaad moeite met een open luchtfilter. Dit is zelfs door Mark verhoeven afgeraden, het verhaal met de LMM klopt gedeeltelijk, maar het heeft ook te maken met de hoeveelheid aangezogen lucht, doordat je een open luchtfilter hebt veranderd het mengsel en wordt er meer lucht aangezogen dan dat de standaard LMM kan waarnemen en bijregelen, een open luchtfilter kan bij Subaru lijden tot motorschade aangezien je met een te arm mengsel rijdt dus ik zou gewoon blijven rijden met de orginele bak, en als je voor een front mounted gaat dan kan je een open luchtfilter pakken, maar dan wordt ook de wagen opnieuw afgesteld en dan kan het weer wel.
