[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4824: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4826: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4827: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4828: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
Wanganwarriors.com • View topic - het plasti-dip topic
And this is the place to discuss exterior related things. Be it BGW's or where to place your stickers.
Postby Robin » 14 Nov 2012, 18:37
Robin
Postby Supernova » 17 Dec 2012, 21:43
Zag vanmiddag dat de Halfords tegenwoordig ook gewoon plasti dip verkoopt :)!
Postby Terror010 » 18 Dec 2012, 00:06
Moet morgen werken en de Halfords zit naast mij dus eens even spieken! Wist al wel dat Slager Automaterialen het heeft!
Silver Evo TME
Terror010
Postby Supernova » 18 Dec 2012, 14:13
Gewoon wel 2 tientjes per spuitbusje maar ach.. Ze hebben ook de complete wheelkit voor 75 euro
Postby Terror010 » 19 Dec 2012, 01:18
Klopt, ff nagevraagd vandaag. Kunnen ze gewoon bestellen!
Silver Evo TME
Terror010
Postby Terror010 » 14 Apr 2013, 23:21
We hebben het allemaal weleens op Youtube gezien inmiddels wat het doet etc.
Ik wilde de Evo 8 Enkei's als zomerset gebruiken en deze voorzien van een laagje vloeibaar rubber. Heb gekozen voor de zogenoemde wielkit. Hier zitten 4 mat zwarte spuitbussen in, een doekje en een pak velgkaartjes. In principe speelkaarten die je tussen de velg en band kan steken.
Allereerst is het best moeilijk spul om te spuiten. Je spuit al heel gauw teveel/ te dik aangezien het bijna transparant uit de bus komt. Het trekt daarna met elke laag steeds meer dicht. Net als gewone spuitlak is het het beste om in dunne lagen te doen ipv meteen dik erop jassen. Je hebt er dus wat geduld voor nodig. Ideaal is het te doen in een wat warmere omgeving, na de 3e laag merkte ik dat het wat minder snel droogde met 1 dag een half zonnetje...
Na het ontvetten (ff goed doen, remmenreiniger op een papierendoekje ofzo en ff goed in alle hoeken en gaten schoonmaken)
Normaal gesproken zou je de band afplakken omdat je hier geen verf op wil hebben, hiermee is dat dus niet zo erg. Eerste wiel had ik niet afgeplakt. Achteraf is dat niet heel slim geweest. Omdat je het spuit komt het overal te zitten, ook tussen je band en velg in de naad. Opzich niet zo erg, maar toch.
Doe je het wel afplakken? Kijk heel erg uit met je plakband! Als je plakband bijv op de rand van je velg zit, kan je bij het verwijderen van je plakband je halve velg meenemen aan PlastiDip.
Tip van de dag:Smeer je banden in met bandenvet of Tire Shine! kijk wel uit dat je het niet op je velg smeert!
Het pakt namelijk niet op een ingevette ondergrond, je wrijft het dan zo van je band/deur/raam etc af waar je het niet wilt hebben!
Ik heb ongeveer 2,5 bussen gebruikt op 4 wielen. Nu kan dat verschillen uiteraard, dit waren 17" velgen en makkelijke brede spaken. Heb je meer spaken zullen het wat meer spuitbussen worden misschien. Heb trouwens alleen de spaken gedaan en niet het velgbed vol in de lak gezet. Heb een randje achter de spaken nog zwart gemaakt maar de rest laten gaan.
Ook heb ik vandaag deze nog meegepakt, vindt het wel tof zo. Tot ik het zat ben, is het er zo weer vanaf :D
Silver Evo TME
Terror010
Postby ricamros » 18 Mar 2014, 16:47
De bek van mijn mx5 ermee gedaan
ricamros
Previous
Return to Exterior
Who is online
Users browsing this forum: No registered users and 3 guests
