[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4824: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4826: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4827: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4828: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3889)
Wanganwarriors.com • View topic - Motor opmooien
Motor opmooien
And this is the place to discuss exterior related things. Be it BGW's or where to place your stickers.
Postby Beez » 05 Nov 2012, 10:58
Hallo,
Wie kan mij vertellen wat er allemaal gespoten kan bij de motor.
Wat er aan slangen veranderd kan worden etc. etc.
Om het geheel er mooier uit te laten zien.
Beez
Postby SstennizZ » 05 Nov 2012, 11:26
~ If something slows you down, move lanes, shift back and FLOOR IT! ~
SstennizZ
Car: Nissan Skyline GTST (R33)
Postby Robin260z » 05 Nov 2012, 12:44
+1 stennisz.
Robin260z
Postby Nishin » 05 Nov 2012, 12:45
Kijk in het project topic van Johan (kapitein iglo)
Postby Beez » 05 Nov 2012, 13:07
Beez
Postby JDMark » 18 Dec 2012, 00:12
Ik ben eigenlijk ook wel benieuwd naar tips waarmee je goed het vuil van je motorblok kan krijgen! :)
JDMark
Postby Kay » 18 Dec 2012, 00:14
Motorreiniger. Ik doe het soms op mijn werk wel eens in de wasstraat, deze heeft een goeie motorreiniger, met warm water. Daarmee spuit je eigenlijk alles wel schoon. Je moet er alleen eentje vinden in de buurt :P.
edit:
En als je dit doet, laat dan wel de motor draaien, als je dat niet doet heb je kans dat ie niet meer aanslaat :lol:
Postby Robin260z » 18 Dec 2012, 00:23
Met wasbenzine kom je ook een heel eind.
Ik heb het hedaan toen mn blok uit de auto was. Dus das een beetje valsspelen.
Bakje wasbenzine en een wegwerk kwas. Stuk jarton of zeiltje eronder.
Daarna in motip enginepaint spuiten ofzo
Robin260z
Postby Kapitein Iglo » 18 Dec 2012, 10:20
Ik heb een tijd geleden allerlei delen uit de auto gehaald, gezandstraald en daarna laten poedercoaten. En daarna startte de auto niet meer. Bleek dat de dynamo zijn massa via de ophangbeugels uit het motorblok haalt. Dus als je de steunen van de dynamo spuit/coat, zorg dan dat de poten kaal zijn en een goede verbinding maken met het blok.
Postby Terror010 » 19 Dec 2012, 01:18
Schoonmaken met Dasty en een oude afwasborstel en doek. Dasty is te koop bij Wibra. Wereldspul!!!
Silver Evo TME
Terror010
Postby Kapitein Iglo » 19 Dec 2012, 09:08
Gaat het nou over schoonmaken of spuiten in de zin van een andere kleur ergens aan geven?
Return to Exterior
Who is online
Users browsing this forum: No registered users and 4 guests
