Heb even snel een handleiding getikt, zal nog wel het 1 en ander missen dus graag jullie gedachten of meningen hierover
Het is in engels geschreven omdat het ook op engelse fora zal komen en dan hoef ik het niet 2x te tikken
(jaja, lui
350Z Brembo front brakes on Nissan S13/S14/S15/Z32/R32/R33/R34
Part list:
350Z Brembo front discs, calipers and pads
Brake lines with a 10x1mm nut on the end (no banjo bolt)
14mm blacksmith drill (blacksmith drills have a smaller shaft to allow them in normal drills)
4x M14x1.5 bolts, 40mm length, grade 12.9 (but 10.9 is also applicable)
Masking tape
Angled grinder and grinding disc
Bleeder tool or someone to push the pedal for you
Technical information:
Watch the orientation of the anti-squeel plates.
First, loosen the front wheel bolts/nuts, jack up the car and support it with axle stands:
If you have spacers undo these too: (have someone step on your brakes for this)
Now first remove the calipers and put it aside, but do not disconnect the hydraulic line otherwise you will need to bleed the whole system.
I usually use a screwdriver through the mounting hole behind the ARB
Remove the brake disc and grind away the edge of the dust plate:
Fit the new brake disc and check nothing touches the disc:
Here comes a the most difficult part.. You will have to drill the holes for the caliper bolts from 12mm to 14mm, the steel of hub is made from is very strong, be prepared to take it to a machine shop or grind your drill a few times.
If you have ABS, put some tape over the sensor or it will be jammed with bits of metal from the drilling proces!!!
Fit the 350Z caliper: The bolts used are: 14x1.5mm 40mm long grade 12.9 (10.9 are also applicable).
The bolts can protrude about 5mm but i made them exactly on the length i needed:
Now fit the brake disc and caliper (without pads and hardware) and check that the disc is exactly in the centre of the calipers:
The calipers should be torqued to 151-152Nm (15.4-15.5Kg-m, 111.4-112.1ft-lb).
Now place the brake pads, pins, cross spring and clips, apply some copperpaste to the back and the sides (when mounted upper and lower edge) of the brake pads:
Now attach the hydraulic line, bleed the brakes and youre done
If you are using new brake pads be sure to follow the break-in procedure.
Before: 280x30mm disc, Z32 brake calipers
After: 324x30mm disc, Z33 brake calipers
Part list:
Masking tape
mooie write-up! en nu is natuurlijk de belangrijkste vraag, hoe voelen deze remmen t.o.v. de z32 remmen???
Er zitten momenteel ebc yellowstuff blokjes in, niet mijn keus maar zaten erbij toen ik de set kocht.
ik kan duidelijk merken dat ik deze blokjes warm moet rijden voordat ze goed bijten, maar zodra ze lekker warm zijn kan ik ook echt goed hard remmen (en zou daarvoor eigenlijk mijn banden ook eerst warm moeten rijden
Kwa gevoel in het pedaal.. met de z32 remmen moest ik altijd het pedaal intrappen om flinke remkracht te krijgen, maar nu heb ik duidelijk dat zodra ik het pedaal aantik dat hij echt gelijk (en hard) remt.
Ik denk dat wanneer ik betere blokjes monteer en de achterkant ook aanpas, dat het helemaal goed zal worden
